Engineering Solutions
PDGS Import Options
PDGS Import Options
PDGS Import Options
@CleanupTol
Value
double
A negative value (default) means to use the auto cleanup tolerance.  A value greater than the calculated auto cleanup tolerance means to use that specific tolerance.
Refer to the CAD Cleanup Tolerance section.
See Also:
PDGS Metadata Support
PDGS Reader Support
CAD Import Options
