Engineering Solutions
PartInfo Macro
PartInfo Macro
PartInfo Macro
The PartInfo macro summarizes a part’s statistics in a dialog.
1.To start the macro, click PartInfo on the Utility Menu.
2.Click component in the main menu area to select a component or click a component in the graphics area to select it.
3.Click proceed. The Part Information dialog appears, which lists the part ID, name, thickness, and material type.
part_info
4.To view additional statistics about the part, click the More Details tab.
5.To display statistics for a different part, select the part in the graphics area or the components selector and click proceed again.
Tip:Click the middle mouse button instead of the proceed button to quickly select components.
See Also:
Nastran Utility Menu
