Engineering Solutions
Nastran1 Page
Nastran1 Page
Nastran1 Page
The following macros are available on the Nastran1 macro menu:
Auto Property Creation
If two or more components points to single property this utility will create a separate property for each component.
Analysis Setup
Load Steps Browser
Generate Nastran subcase definitions.
BCTABLE Manager
Create, edit, and delete BCTABLEs from a convenient tabbed interface.
Rigids & Welds
Rigid Spider
Create a spider (RBE2 elements) around holes.
Comps, Props & Mats Info
PartInfo
Review details for a specified part.
Component Table
Create, review, and edit components
Property Table
Create, review and edit properties
Material Table
Review and edit MAT1.
Miscellaneous
RSSCON Create
Create a transition element between solids and shells.
RSPLINE Create
Create RSPLINE elements as bulk unsupported cards.
TABLE Create
Create a tabular function card.
