The Materials Table is used to review and edit MAT1.
1. | From the Nastran Utility menu, click Material Table. All MAT1 in the model are displayed. |
1. | From the Nastran Utility menu, click Material Table. |
3. | The following dialog is displayed. |
4. | Fill in the necessary fields. |
5. | Click Create. The material is created and added to the Material Table. |
2. | Use the check boxes to select the material to be deleted. Check Select all to select all materials. Check the small X box next to the check box to delete the material. |
See Also:
Nastran Utility Menu
