Engineering Solutions
RSSCON Create
RSSCON Create
RSSCON Create
The RSSCON Create macro creates an RSSCON element that connects the shell and solid. Because RSSCON elements are not directly supported, these elements are stored in unsupported bulk data cards.
To create an RSSCON element:
1.Click the RSSCON Create macro.
2.Pick the elements to be connected in the model.
3.Click proceed.
Note:When you renumber element or node IDs, RSSCON elements are not also updated because they are supported only as text.
