Engineering Solutions
PBAR, PROD Opti.
PBAR, PROD Opti.
PBAR, PROD Opti.
This utility may be used to set-up size optimization for multiple PBAR or PROD properties
1.Click PBAR, PROD Opti.
You are prompted to select a number of properties.
2.Select properties.
3.Select either a PBAR or a PROD card and a section type.
4.Enter initial values and bounds.
5.Click calculate.
Depending on the cross section, a number of design variables, equations, and DVPREL2 cards are generated.
See Also:
Utility Menu
