Engineering Solutions
Reg. Volfrac
Reg. Volfrac
Reg. Volfrac
The Reg. Volfrac utility creates a regional volume fraction response for a number of components, properties, or materials.
1.Click Reg. Volfrac.
You are prompted to select a number of components, properties, or materials.
2.Select the entities.
Volume responses are generated for each entity (vol#).
An equation is then created to calculate the total volume fraction over the entire region.
A function response is generated using the equation with reference to the volume responses.
See Also:
Utility Menu
