Engineering Solutions
Periodic Mesh
Periodic Mesh
Previous topic Next topic Expand/collapse all hidden text
Periodic Mesh
To access this utility, click Mesh > Surface Mesh 2D > Periodic Mesh.
The Periodic Mesh utility can be used to generate a grid containing rotational and/or translational symmetric boundaries, for example rotating machinery. In the first step, the mesh on the source geometry has to be generated using any of Engineering Solutions surface meshing algorithms, for example 2D mesh with BL. In the second step of the Periodic Mesh utility, the mesh is mapped from the source geometry onto the target geometry. In addition to source and target geometry, detailed information about the transformation can be optionally entered.
hmtoggle_plus1greyPeriodic Mesh Dialog
The Periodic Mesh dialog contains the following buttons:
Button
Action
Check/Modify Geometry
Performs a check to determine whether source and target geometry are rotational and/or translational symmetric or not.
Check Mesh
Performs a check for source and target mesh to determine if symmetry exists.
Map Mesh
Maps the mesh from the source geometry onto the target geometry.
Reject
Rejects the generated mesh.
Close
Closes the dialog.
periodic_mesh_dialog2
hmtoggle_plus1greySymmetry Options
To describe the mesh transformation between source and target geometry, expand the Symmetry options portion of the dialog to enter detailed information.
The following options are available in the Symmetry options section:
Option
Translation
Defines the translation vector by two nodes.
Rotation
Defines the rotation by an arc (defined by three nodes) or by an axis and a rotation angle.
Both options can be used simultaneously for one transformation.
periodic_mesh_symmetry
After a successful mapping step, information about the transformation is plotted in the log region of the dialog.
periodic_mesh_log_step
See Also:
Meshing
