Engineering Solutions
Ply Geometry Smoothening
Use this tool to convert FE ply geometry into geometry ply and export the plies as STEP files using OS-smooth functions. The STEP files can be imported into CAD systems.
1.Select the FE ply to be converted into geometry shape.
2.Select either line or surfaces geometry to be exported as step files.
3.Zero is used for the smooth iteration if the exact shape is to be preserved without smoothing the boundary. Otherwise, use 10-20 for the iteration.
4.Provide the step file name.
5.Geometry plies are created and exported to step files.
fe_plies
FE plies
plies_without_smoothing
Geometry plies without smoothing
plies_with_os_smooth
Geometry plies with OS-smoothing
See Also:
Aerospace Menu
