Engineering Solutions
Aerospace Menu
Aerospace Menu
Aerospace Menu
The following tools are available via the Aerospace menu, which is a useful utility to build and view aerospace models. The menu has minor modifications depending on the solver that is loaded.
Assembly
Opens the following tools: Assembly from CSV, Module from CSV, and organizing Aerospace components.
Panel
Opens the Midsurface modeling (Midsurface Mesh dialog) tool.
Beams
Opens the Beams from lines, Beam Sections from CSV and Beam Auto Property tools.
Composites
Opens the following tools: PCOMP from CSV, Ply Geometry Smoothening, Ply Auto Rename, FE Absorb Plies, Material Orientation and Shell To Solid Conversion.
Loads/BCs
Opens the PLOAD1 Create and Review, Map Force and Mass, Line loads, RSpline and Transformation Tool. The Transformation Tool is also available by clicking Tools > Transformation Tool.
Connections
Opens the Fastener setup and Sewing Tools.
Spatial ID Manager
Opens the Spatial Renumbering tool.
Display
Opens the Orientation Review tool. This tool is also available by clicking Tools > Orientation Review.
Results
Opens the Matrix browser and Results Explorer. The Matrix browser is also available by clicking Tools > Matrix Browser.
Certification
Allows you to input and save files.
