Engineering Solutions
Assembly Tools
Assembly Tools
Previous topic Next topic Expand/collapse all hidden text
Assembly Tools
The purpose of the assembly tools is to create an assembly structure from a .csv file definition. You can create an assembly structure (product structure) similar to a PDM system using the Model/Assembly browser or using the Parts browser (Module browser). Both tools are provided using the same .csv file format described below. You can import this file and the tool automatically creates the product structure in the database. You can drag and drop components into the assembly tree to organize the models in a similar manner to CAD or PDM product structures.
product_structure_def
This image shows a .csv file format for the product structure definition
When you import this .csv file as an assembly or module you will get the following organization in the Model browser (assembly csv) or Part browser (module csv).
assembly_options
product_structure_model_browser
A product structure is created in the Model browser
hmtoggle_plus1greyOrganizing Aerospace Components
Use this tool to split a monolithic FE model (imported from solver data files) into suitable HyperWorks components. These components are then manually moved into assembly product structures to create a real world aerospace model. Two useful methods can be used to split the monolithic FE model into components. One involves using the coordinate system and the other uses ID ranges.
aero_assembly_options
Using the coordinate system
Shell and beam models can be split using a local coordinate system.
single_component_model
This image shows a single component model
1.Click Assembly > Organize Aero Components > Using Cord-System.
2.Select the local system and the elements to be organized. It is required that you create empty components where these elements are to be split using the coordinate system. The elements are separated based on the system directions (within the Angle Deviation tolerance) and are moved to the empty components.
organize_into_components
split_model
The model is split into components using the local system direction
Using ID ranges
Aerospace users typically assign ID ranges to specific components. Using these definitions from a .csv file, the elements are automatically separated into component names defined in the .csv file.
id_range_csv_file
This image shows an ID range .csv file with component names
elements_sep_components
Based on ID ranges, elements are separated into components
See Also:
Aerospace Menu
