Use this tool to connect two dissimilar meshes using displacement constraint elements.
Connecting two dissimilar meshes using the Nastran displacement constraint element-RSpline
1. | Select the Independent nodes. |
2. | Select the Dependent nodes and their degrees of freedom. A new component will be created and the RSpline elements are added to the component. |
3. | Click the Edit tab to correct the sequence or review it. |
Dissimilar meshes are connected with RSpline element
