These tools enable the creation of 1D elements from surface lines, organizing them into components. They also offset/orient these elements based on the attached shell elements and calculating properties of these 1D elements from 3D solid or shell FE element sections.
Use this tool to create 1D elements to match the existing shell elements from lines (surface edges). Normally surfaces are split into panels using lines and planes. Then shell meshes are created on those split surfaces. This tool extracts 1D elements to match the shell elements along the split lines of the surface and separates them into predefined components based on system direction. Each system direction can have different types of 1D elements (bar, beam or ROD properties). This image shows a shell element model with panel surface edges (green edges) where the beam will be created
This image shows standard beam section definitions from a .csv file
1D elements are created to match the shell elements and correct beam sections are assigned |
This tool is identical to the Assembly Organize by Coordinate System tool. The purpose is to separate all of the 1D beam elements into components based on local system directions.
Use this tool to update 1D element properties, change the orientation, or assign offset to existing BEAM elements. The offset and orientation is based on the attached shell element normal and shell element thickness.
Using the beam Update tool, beam sections can be automatically calculated from 3D solid or FE shell/beam models. The beam properties are calculated from the FE model and are assigned to the center beam (the white line in the middle). Beam properties are calculated and assigned to each beam |
Use this tool to quickly display the beam properties without using the HyperBeam tool or using 3D beam display.
Beam property Display tool |
