Engineering Solutions
Beam Auto Property
Beam Auto Property
Beam Auto Property
Use this tool to calculate beam properties from a solid or FE model.
1.Create beam elements (Plotel) where the beam elements need to be located.
2.Assign a solid model or existing FE model.
3.Click Create.
4.If you need equal offset at each end, activate the Equal offsets on both ends checkbox.
solid_beam
Solid beam
automatic_beam
Automatic beam sections created by cutting the solid model
See Also:
Aerospace Menu
