Engineering Solutions
Material Orientation
Previous topic Next topic Expand/collapse all hidden text
It is often desired to create material orientation based on curve direction for composite modeling. This tool is applicable for shell element only. For example, if the material orientation is to follow a radial or tangential direction of a circular cut, then radial/tangential material angle is created for each element card. The ply angle will be based on that material direction.
hmtoggle_plus1greyBy Curve
Using curves/lines to create material direction:
1.Select the elements for which a new material angle will be assigned.
2.Select the lines or list of nodes to define the material direction. The element centroid will be taken and projected to the closest line/node segments and the line tangent direction will be found to assign the material angle.
circ_pattern
A circular pattern of the material orientation is assigned based on the outer circular line direction
Other material orientation tools are also available.
material_orientation2
By Node: Element material direction can be assigned using two nodes.
material_orientation3
material_orientation4
Two nodes are selected for material direction
material_orientation5
Material direction in the same direction as two nodes
hmtoggle_plus1greyBy System ID
The X axis of the selected system is projected to the elements to create element material direction.
material_orientation6
X axis of the system is used for projection
hmtoggle_plus1greyBy System Axis
You can select a local system and the direction of the axis to be projected to elements and create material direction.
material_orientation7
System local axis 2 is projected to create material system
hmtoggle_plus1greyBy Angle
You can provide an angle by which material direction is rotated from the element N1-N2 direction.
material_orientation8
Element N1-N2 direction
material_orientation9
Material system is created at an angle to N1/N2 direction
See Also:
Aerospace Menu
