In a real life application, necessary preparation work needs to be done to get the module representation files to a state that is ready for assembly. Use the Prepare Module tool to accomplish this goal.
In Prepare Module mode, the HyperMesh database is first cleared to remove any potentially conflicting FE entities and then the root representation file is loaded into HyperMesh. A module ID summary is presented with all necessary information needed for you to determine if the IDs need to be renumbered and what range they should be renumbered to.
Once an appropriate ID management action has been applied, the Prepare Module tab opens in the browser area with sub-tabs designed to help you perform many functions, such as:
• | Add spider: Add spiders to a round hole. Select a type, DOFs and pick center (RBE3 only) and edge nodes, then click Create. |
• | Add PLOTEL: Helps you with PLOTEL display elements. |
• | Edit systems: Relocate or orient the module by modifying the reference local coordinate system. This option takes you directly to the System panel to edit existing systems. |
• | Orient and position: Help translate and rotate FE entities. Input values in the appropriate fields. |
• | Assign damping: Help fill GE field of MAT1 cards. Enter a damping value in the input box and click All or Select to apply the damping values to all or selected material cards. |
• | Impose forming effect: Help generate forming effect on sheet metal panel thickness for FE representation includes. |
In addition, a number of functionalities on the Tagpoints tab of the Edit Module, such as Add, Assign and Generate PLOTEL elements are enabled for you to manually add tagpoints and assign them to grids in the module.
A Tagpoint Mapping tool is also available in the Prepare Module tab via the icon. The mapping tool is able to reconcile in bulk the current tagpoint definition in the assembly database with what is in the root module file. You can also create new tagpoints by reading a .csv file that contains hard point coordinate and label information.
Once all modules are finished preparing, four representation file save options with information on ID renumbering are presented.
• | Yes: The root representation file is to be saved, in this case, intra and inter ID conflict flag will be set to Yes. |
• | No: The root representation file is not to be saved, in this case, intra and inter ID conflict flag will be set to No. |
• | Cancel: The exit Prepare Module Mode action is aborted. |
• | No, but VALIDATE: In this case there is no change to the file and no need to save the file, but intra and inter ID conflict flag will be set to Yes. |
Once all of the modules have been prepared, you can review the assembly ID ranges and conflict setting from the ID View of the Assembly browser. At the individual module level, the ID tab of the Edit Module will also be populated.
The Properties tab in Edit Module is used to:
In the prepare module mode, mass extraction is possible using either of the options listed below.
Once the mass information is updated, clicking Generate automatically creates rigid body representation for the module. This LP representation is available as one of the representation types for the module, which allows you to select this LP representation type according to your loadcase in the Analysis Manager.
