Engineering Solutions
RADIOSS Utility Menu
The RADIOSS Utility menu is accessible when the RADIOSS user profile is loaded. It contains shortcuts and tools that help simplify RADIOSS tasks.
To load the RADIOSS user profile:
1.From the Preferences menu, select the User Profile option.
2.Select the RADIOSS profile.
3.Select the Block110, Block100, Block91, Block51, Block44 or Block42 template.
The RADIOSS user profile activates the RADIOSS macro, sets the FE input reader to RADIOSS, and loads the corresponding RADIOSS FE output template.  Also, the graphical user interface becomes RADIOSS specific, renaming and/or removing some panels and options.
The RADIOSS Utility menu contains the Tools sub-menu in addition to the standard Utility menu functions.
See Also:
Tools Menu
Other Tools
