Engineering Solutions
Tools Menu
Tools Menu
Tools Menu
The Tools menu contains utilities that simplify many common tasks in RADIOSS.  The following macros are included:
Create Part
Creates a new component quickly.
Clone Part
Creates a new part from the properties of an existing part.
Part Info
Displays statistics of a selected part.
Material Table
Allows you to easily create materials for RADIOSS.
Component Table
Opens the Components and Properties table, displaying a tabular list of the \PARTs (components) in the model.
Relative Displacement
Helps create the TH/SPRING card, which supports time histories with spring output.
RBODY Manager
Displays information about rigid bodies in the model.
BCs Manager
Creates boundary conditions of any load collector type other than ACTIV.
ADMAS Manager
Displays information about masses in the model.
Accelerometer
Creates and edits time history ACCEL cards to track accelerometer output requests.
Welds
Creates meshless welding using the RADIOSS interface type 2 and springs.
See Also:
RADIOSS Utility Menu
