The RADIOSS Component Table is an interactive tabular list used to represent RADIOSS components with associated properties and materials. It is accessed by loading the RADIOSS user profile and clicking the Component Table button on the Utility menu.
The table contains a variety of tools that allow you to review, edit and update the model. The essential features are:
• | RADIOSS components with various associated properties and materials are listed in separate columns. |
• | You can select the column types from a set of available options. |
• | There are two modes of operation: review and editable. The review mode allows you to quickly review the component information without changing any values. The editable mode allows you to change values for the selected components. |
• | There are enhanced selection, review, display and filter options for components. |
• | Components can be sorted according to any available column. |
• | The current configuration is saved automatically to a file at the end of a session and recalled on reload. You can also save and load a configuration file. |
• | The table data can be exported in CSV and HTML formats. |
• | Right-click the table to display menu options. All pull-down menu options are also available using a right-click. |
• | Columns can be moved or swapped by holding the left mouse button on a column title and dragging it to the desired location. |
• | Columns can be resized by positioning the cursor along a column border, pressing the left or right mouse button and dragging the border to a new position. |
• | The SHIFT or CTRL key combined with a left-click can be used to select multiple rows. |
The following tools are available in the RADIOSS Component Table:
Refresh |
Regenerates the table with all the parts in the model |
Sets the table mode to editable mode, allowing you to change values for the selected components |
Enables the filtering GUI |
Allows you to specify the number and type of columns listed in the table |
Save |
Saves the information listed in the table in CSV or HTML format |
Quit |
Quit the table function. |
All |
Selects all rows or parts |
None |
Selects none or deselects parts/rows that were previously selected |
Reverse |
Reverses the selection |
Displayed |
Selects the rows or the displayed parts |
User |
User graphic interaction to select parts |
By default, the table is invoked with only the displayed parts. You can refresh the table to show a new part being displayed or use one of the following display commands.
All |
Displays all the components in the model |
None |
Turns off every component displayed |
Reverse |
Reverses the display of the part |
Show selection |
Displays the components of the selected rows |
Show only Selection |
Displays only the components of the selected rows |
Hide selection |
Hides the components of the selected rows from the display |
By Material |
Displays components sorted by material |
By Properties |
Displays components sorted by properties |
By Thickness |
Displays components sorted by thickness values |
Delete Selection |
Deletes selected rows (parts) from the model |
Create Part |
Opens the Create Part macro. |
Set MatDB Path… |
Opens a dialog on which you can set the location of an external database of material definitions. |
Refresh Material List |
Updates the list of available materials in the Component Table. |
