Engineering Solutions
Create Part
Create Part
Create Part
The Create Part macro enables you to create components on-the-fly. It can be accessed by clicking Create Part on the Utility menu.
Type a name for the new component in the Part name field and select a color by clicking the adjacent color icon.
Select a section in the Section field by choosing Create New (create a new section), Same As (create a new section based on an existing section), or Model (select an existing section) from the selection menu.
Select a material for the component in the Material field by the same method as described above for the Section field.
Click Create to either create or create and edit the card.
See Also:
Tools Menu
RADIOSS Utility Menu
