ADMAS Manager
The ADMAS Manager is a tool accessible in the RADIOSS Utility menu. The ADMAS Manager provides the following features in one convenient tab:
• | Display all masses in the model |
• | Display individual masses |
• | Create new, and edit existing, simple and advanced mass formulations |
• | View, find attached, and update details of individual ADMAS, though the card editor and the Admas panel. |
Create ADMAS
To create a new mass, make a selection in the Type field.
• | M option - nodal mass defined separately on each selected node. |
• | MADV0 option - nodal mass defined on the selected nodes as a set. Defined mass is the mass added to each node in the set. |
• | MADV1 option - nodal mass defined on the selected nodes as a set. Defined mass is the total mass added to nodes in the set. |
See Also:
