The Material Table macro, located on the Tools page of the RADIOSS Utility menu, allows you to easily create materials for RADIOSS.
To use the Material Table macro:
1. | Select the Tools macro page. |
2. | Click the Material Table macro button. |
All existing materials are retrieved and populated in the table.
The columns can be sorted by clicking the column heading, and can be resized by clicking and dragging the edges of the columns within the table itself.
Command Buttons
Button
Action
Create/Load
Allows you to create a new material. There are three options, New, Same as and Load/edit.
New
Opens entry fields and menus that allow you name and select the properties of the new material.
To use the New option:
1. | Enter a name for the new material in the New Material Name: field. |
2. | Click the Material type: switch and select a material type from the drop-down menu. |
This menu contains the subcategories of materials. Each sub category clearly indicates the supported material type. Materials are listed with the MAT# and complete RADIOSS type. Select the type and click the create/edit button to create a material and open the card edit mode.
3. | Input the appropriate values as necessary for the material in the card image. |
4. | After you input the values, click return to exit from the panel. |
5. | Click Return in the Material Table. |
Same as
The parameters are exactly the same as New except that the Material Type alias, existing material for Same as must be selected from the table.
1. | Left click the material row that you want to duplicate. |
4. | Specify a name for the new material in the New Material Name field. |
5. | Click create/edit to display the card image. |
6. | Specify the appropriate values and click return on the panel. |
7. | Click Return in the material table. |
Note: | The E, Nu, and Rho columns are populated only if the fields are available in the material card. |
Load/edit
The Load/edit function allows you to change the material type of a selected material and load the appropriate card image so that you can make changes to it.
1. | Left click the material row that you want to edit. |
3. | Make a selection in the Material Type: field. |
4. | Click the Load/edit button. |
5. | Specify the appropriate values and click return on the panel. |
Edit
Displays the card image, where you can input values.
Merge As
Check duplicates
