Engineering Solutions
Configure Columns
Configure Columns
Configure Columns
Column types can be selected from the Table > Configure > Columns menu option. The table displays only the selected columns. The available columns types are:
Title
Vis
Visualization status. 1 = display on, 0 = display off
Part Title
Title of the part
Part id
HyperMesh ID of the component
Prop Name
HyperMesh name of the property
Prop Id
HyperMesh ID of the property
Prop Type
Property type associated with the component
Material name
Material name associated with the component
Material id
Material ID associated with the component
Material type
Material type associated with the component
Thick
Thickness of elements specified in *section_shell
Elems
Number of elements in the component
Nodes
Number of nodes in the component
Color
Component color
SigY
Harden_Param(b)
Mass
Total mass of the component
cg_x
Center of gravity for the x coordinate
cg_y
Center of gravity for the y coordinate
cg_z
Center of gravity for the z coordinate
Comp_table_configure
See Also:
Component Table
RADIOSS Utility Menu
