Engineering Solutions
Solver Interfacing
Solver Interfacing
Solver Interfacing
It is recommended that you create a new component collector before starting the SPH mesh generation so that the generated mesh is stored in a separate collector. The generated SPH elements are mapped to the following cards for each supported user profile:
RADIOSS
SPHCEL
In addition, a new property card PROP/SPH is created for RADIOSS interface.
LS-Dyna
*ELEMENT_SPH
PAM-CRASH 2G
SPHEL
Abaqus
*SECTION CONTROLS
See Also:
SPH Mesh
