Engineering Solutions
Sorting Midsurfaces
Sorting Midsurfaces
Sorting Midsurfaces
Manually sort midsurfaces after extraction using the sort tool in the midsurface panel.
1.In the midsurfaces panel, select the sort tool.
2.Select a method for sorting midsurfaces.
<~[o]riginal name> comp creates new components by removing the first letter of the original component name and replacing it with a ~ and sorts the midsurfaces accordingly.  For example, my_comp -> ~y_comp.
<Midsurface #nn> comp creates components with the name Midsurface #, where # increases for each component that exists for the input surfaces/solids.
original comp organizes the midsurfaces into their parent surface/solid components.
<original name~> comp creates components using the original component name and adds ~ at the end.
<original nameN> comp creates new components by incrementing the name of the original.
3.Click sort.
See Also:
Extracting Midsurfaces
Midsurface Panel
