Engineering Solutions
To change a curve's attributes
1.Click the curve that you wish to modify
Either click the curve in the curve list
Or
Click the curve in the graph area, if it is already set to Display.
2.Make any desired changes to the curve’s attributes:
Modify each X and/or Y value by clicking it, pressing the <delete> key to erase the current value, and then typing in a new value.
Change the Color by clicking the colored box.
A list of available colors displays; click the desired color to select it.
Click the display checkbox to toggle the display of the curve in the graph area.
To place a marker symbol at each point on the curve, select a symbol from the list box.
To change the symbol spacing, select a number from the every: list box.
For example, if you choose "3" then only every third point will display as a symbol.
Select a Line style to change the curve’s line from solid to dotted, or show no line at all.
Note:If you choose no line, the line’s symbol points will still display.
To draw the curve in a thicker line, click the thick line checkbox.
