Engineering Solutions
Using the Curve Editor
In the Curve Editor you can view and modify graphed curves. Changes made in the Curve Editor are automatically sent back to Engineering Solutions, but changes made in a panel are not automatically sent to the Curve Editor. For this reason, if you leave the Curve Editor open while making changes within the XY plotting panel, you must click update in the Curve Editor to import the changes.
The Curve Editor contains four main areas, outlined with colored boxes in the image below: the curve list (green), curve attributes (blue), graph area (red), and graph attributes (cyan).
curve_editor_areas
See Also:
XY Plotting
