After you have read or created curves, you can select which curves in the database you want to display on an xy plot.
To select curves for a plot, select the Plots panel and click select curves. A list of the available curves in the database are displayed. The names of the curves that are already displayed on the current xy plot are highlighted. Modify the list by selecting the curves by name and removing or adding the curves to the current plot as desired and click return.
