Engineering Solutions
Delete a Rake
Delete a Rake
Delete a Rake
1.From the Streamlines panel, select a rake from the Rakes list.
2.Click Delete (located in the lower left corner of the panel).
Or
1.From the Streamlines panel, right-click the name of a rake in the Rakes list and select Delete (from the context menu). The rake is removed from the list and the window.
See Also:
Streamlines
