Engineering Solutions
To display curves in the graph area
1.Click the desired curve in the curve list. The curve’s attributes fill in the fields in the curve attributes area.
2.Modify the curve attributes as needed.
3.Right-click on the curve in the list and select display only from the context menu. The curve displays in the graph area.
