1. | Click File > Export. |
2. | Select the Export Geometry ![]() |
3. | From the File type drop down list, select the type of file you want to export. |
4. | In the File field, click the folder icon to browse for the file to export. Once the file is selected, click Open. |
5. | To set further options, click Export options to expand the Export tab. |
6. | In the Export field, select All or Displayed. If Displayed is selected, only the geometry currently showing in the graphics area will be exported. |
7. | Enter settings for the fields Units, Export, Outer loop and Layers. |
8. | Activate the Prompt before overwrite checkbox if desired. |
9. | Click Export to apply the settings and export the model. |
