Engineering Solutions
Review and Modify an Existing Design Variable
1.Select the design variable to be edited from the Laminate Browser.
The Define/Edit and Review panes are populated with the selected design variable definition.
2.Edit the data fields in the Define/Edit pane.
Data may be cut, copied from, pasted to, or deleted from the data fields using the toolbar, pull-down Edit menu or CTRL+X, CTRL+C, CTRL+V, and CTRL+D, respectively.
3.Clicking Clear will reset all fields to their default values.
Each change is reflected in the Review pane.
4.Click Apply to save the changes for the current HyperLaminate session. (It is important to remember that the HyperMesh database is only updated on exit from HyperLaminate.)
The final design variable definition is displayed in the Review tab.
