Engineering Solutions
Review and Modify an Existing Laminate
1.Select the laminate to be edited from the Laminate Browser.
The Define/Edit and Review/Results panes are populated with the selected laminate definition.
2.The laminate definition may be modified in the Define/Edit pane in a manner similar to defining a new laminate. (See Define a New Laminate.)
3.Click Update Laminate to save the changes for the current HyperLaminate session. (It is important to remember that the HyperMesh database is only updated on exit from HyperLaminate.)
