Engineering Solutions
Review or Modify an Existing Material
1.Select the material to be edited from the Laminate Browser.
The Define/Edit and Review/Results panes are populated with the selected material definition.
For the OptiStruct, Nastran and Ansys user profiles:
1.Edit the data fields in the Define/Edit pane.
Data may be cut, copied from, pasted to, or deleted from the data fields using the toolbar, pull-down Edit menu, or CTRL+X, CTRL+C, CTRL+V, and CTRL+D respectively.
2.Clicking Clear will reset all fields to zero.
Each change is reflected in the Review/Results pane.
3.If desired, a new name for the material may be entered in the Material: field, or the material color may be altered by clicking the color swatch and selecting a new color from the pop-up color palette.
4.Click Apply to save the changes for the current HyperLaminate session. (It is important to remember that the HyperMesh database is only updated on exit from HyperLaminate.)
The final material definition is displayed in the Review tab.
For the Abaqus user profile:
1.Click Edit to see the material definition in the HyperMesh card previewer.
2.Make all desired changes to the material definition in the card previewer.
3.Click return.
This returns you to the HyperLaminate GUI.
4.If desired, a new name for the material may be entered in the Material: field or the material color may be altered by clicking the color swatch and selecting a new color from the pop-up color palette.
5.Click Apply to save the changes.
