1. | Translate the first punch file and name the results file name.res (extension optional). |
The results file, result.res, is created.
2. | Translate the second punch file and name the results file name1.res (extension optional). Observe the number following name. |
The results file, result1.res, is created.
3. | Read both result files in Engineering Solutions. |
4. | Select the result.res file and all your results files are read into Engineering Solutions (result1.res, result2.res, and so on). |
Note: | Keep in mind that in the initial punch file, both DISPLACEMENT and STRESS are in SUBCASE 1 but, now DISPLACEMENT is in SUBCASE1 and STRESS is in SUBCASE2. |
