Engineering Solutions
Post-Processing Analysis
The post-processing functions allow you to review the results files and databases generated by external codes. Results files can be translated into HyperMesh results databases which are then read into HyperMesh for post-processing. This translation is done using result translators; for more information, refer to the individual translators in the Interface help system.
This section describes the structure of a HyperMesh results database and explains how to use the post-processing functions to create contour, assigned, deformed, and vector plots.
Post-processing functions include:
Specifying the Results File
Creating Deformed Geometry Plots
Creating Animations
Creating Vector Plots
Creating Contour Plots
Creating Assigned Plots
Adding Plot Identification - Legends and Titles
Inspecting the Results
