The Deformed panel allows you to display the deformed geometry of your model statically, in either wire frame or hidden line mode.
The selected simulation must have a data type in it that contains nodal displacement records. It is from the data contained with the nodal displacement records that allows the calculation of the deformed geometry of the structure.
