In order to perform post-processing functions, you must first specify the name and location of the results database. There are two ways to select a results file:
• | Click File > Load Results File icon and select the .res file. |
• | In the Global panel, for results file, enter the path and name of the results file or click browse to select a file using the browser. |
Results subpanel
