A contour or assigned plot provides a fast, convenient way of viewing the results of a large number of elements. When you want to determine the actual value that an analysis code has calculated for a node or element, you can select the node or element after the results-based plot has been created. The ID, simulation and data type, and value of the node or element are displayed in the menu area.
