Engineering Solutions
Tribon Import Options
The Tribon reader uses the tribon_reader.ini file with the following available options:
@CleanupTol
Value
double
A negative value (default) means to use the auto cleanup tolerance.  A value greater than the calculated auto cleanup tolerance means to use that specific tolerance.
Refer to the CAD Cleanup Tolerance section.
@DoNotMergeEdges
Value
on
Preserve the original geometry edges, instead of merging them together during the import cleanup phase.
off
Merge edges together during the import cleanup phase (default).
@ImportCutoutProfiles
Value
on
Import cutout profiles.
off
Do not import cutout profiles (default).
@ImportFaceplatesAsSurfaces
Value
on
Import faceplates as surfaces if the surface description is present in the file, otherwise import as curves (default).
off
Import faceplates as curves.
@ImportHoles
Value
on
Create holes (default).
off
Do not create holes.
@ImportNotchProfiles
Value
on
Import notch profiles.
off
Do not import notch profiles (default).
@ImportPanelProfiles
Value
on
Create curves along the panel profiles.
off
Do not create curves along the panel profiles (default).
@ImportPillarsAsSurfaces
Value
on
Import pillars as surfaces if the surface description is present in the file, otherwise import as curves (default).
off
Import pillars as curves.
@ImportStiffenersAsSurfaces
Value
on
Import stiffeners as surfaces if the surface description is present in the file, otherwise import as curves (default).
off
Import stiffeners as curves.
@ImportUnboundedCurvedPlates
Value
on
Import curved plates lacking boundary descriptions (default).
off
Do not import curved plates lacking boundary descriptions.
@MetadataPrefix
Value
string
The string is prefixed to all metadata names. No prefix is used by default.
See CAD Metadata Naming for more details.
@PreferDetailed
Value
on
When multiple representations of a Tribon object are available, import the most complex one (default).
off
When multiple representations of a Tribon object are available, import the least complex one.
@ScaleFactor
Value
double
Define the model scaling factor during import.
Default is 1.0.
@TribonCurvedPlateColor
Value
string
A RGB description of the color to use for curved plates, with values ranging from 0.0 to 1.0 (for example "0.1,0.5,0.4"). If not specified, default color management will be utilized.
@TribonCurvedSimpleContourColor
Value
string
A RGB description of the color to use for curved simple contours, with values ranging from 0.0 to 1.0 (for example "0.1,0.5,0.4"). If not specified, default color management will be utilized.
@TribonCurvedStiffenerColor
Value
string
A RGB description of the color to use for curved stiffeners, with values ranging from 0.0 to 1.0 (e.g. "0.1,0.5,0.4"). If not specified, default color management will be utilized.
@TribonFlangeColor
Value
string
A RGB description of the color to use for flanges, with values ranging from 0.0 to 1.0 (for example "0.1,0.5,0.4"). If not specified, default color management will be utilized.
@TribonPlaneBracketColor
Value
string
A RGB description of the color to use for plane brackets, with values ranging from 0.0 to 1.0 (for example "0.1,0.5,0.4"). If not specified, default color management will be utilized.
@TribonPlaneDetailedContoursColor
Value
string
A RGB description of the color to use for plane detailed contours, with values ranging from 0.0 to 1.0 (for example "0.1,0.5,0.4"). If not specified, default color management will be utilized.
@TribonPlaneFaceplateColor
Value
string
A RGB description of the color to use for plane faceplates, with values ranging from 0.0 to 1.0 (for example "0.1,0.5,0.4"). If not specified, default color management will be utilized.
@TribonPlaneFlangeColor
Value
string
A RGB description of the color to use for plane flanges, with values ranging from 0.0 to 1.0 (for example "0.1,0.5,0.4"). If not specified, default color management will be utilized.
@TribonPlanePillarColor
Value
string
A RGB description of the color to use for plane pillars, with values ranging from 0.0 to 1.0 (for example "0.1,0.5,0.4"). If not specified, default color management will be utilized.
@TribonPlanePlateColor
Value
string
A RGB description of the color to use for plane plates, with values ranging from 0.0 to 1.0 (for example "0.1,0.5,0.4"). If not specified, default color management will be utilized.
@TribonPlaneSimpleContourColor
Value
string
A RGB description of the color to use for plane simple contours, with values ranging from 0.0 to 1.0 (for example "0.1,0.5,0.4"). If not specified, default color management will be utilized.
@TribonPlaneStiffenerColor
Value
string
A RGB description of the color to use for plane stiffeners, with values ranging from 0.0 to 1.0 (for example "0.1,0.5,0.4"). If not specified, default color management will be utilized.
@TribonSubFaceplateColor
Value
string
A RGB description of the color to use for sub-faceplates, with values ranging from 0.0 to 1.0 (for example "0.1,0.5,0.4"). If not specified, default color management will be utilized.
@TribonSubFlangeColor
Value
string
A RGB description of the color to use for sub-flanges, with values ranging from 0.0 to 1.0 (for example "0.1,0.5,0.4"). If not specified, default color management will be utilized.
@TribonSubStiffenerColor
Value
string
A RGB description of the color to use for sub-stiffeners, with values ranging from 0.0 to 1.0 (for example "0.1,0.5,0.4"). If not specified, default color management will be utilized.
See Also:
Tribon Metadata Support
Tribon Reader Support
CAD Import Options
