Engineering Solutions
Tribon Metadata Support
The Tribon reader generates the following metadata:
BENDING_RADIUS
Entities
string
assems
The value of the BendingRadius attribute for a plane flange group.
COLOR_RGB
Entities
string
comps
Three RGB values, ranging from 0 to 255, indicating the color for the object.
Generated when the corresponding @Tribon<object>Color option is used.
COMP_ID
Entities
string
assems
The value of the CompId attribute for a plate or bracket.
DATA_TYPE
Entities
string
assems
The value of the DataType attribute for a panel.
EXTENT_MAX
Entities
string
assems
The value of the maximum extent of a block or panel, as retrieved from the Max attribute of the object.
EXTENT_MIN
Entities
string
assems
The value of the minimum extent of a block or panel, as retrieved from the Min attribute of the object.
FORCE_UNITS
Entities
string
assems
The value of the ForceUnits attribute for a ship units object.
FUNCTIONAL_PROPERTY
Entities
string
assems
The value of the FunctionalProperty attribute for a panel or a group of sub-objects of a panel.
HEIGHT
Entities
string
assems
The value of the Height attribute for a plane flange group.
LENGTH_UNITS
Entities
string
assems
The value of the LengthUnits attribute for a ship units object.
MATERIAL_DIRECTION
Entities
string
faces
The value of the MaterialDirection attribute for a flange, curved panel or knuckled panel.
MATERIAL_SIDE
Entities
string
assems
The value of the material side data for a plate group or bracket group.
OFFSET
Entities
string
assems
The value of the offset data for a plate group.
RENDERING_TYPE
Entities
string
assems
The value of the Type attribute for a ship rendering object.
RootSystemID
Entities
string
assems
The root system ID (OID) for various structures such as web frames, transverse bulkheads, longitudinal bulkheads, stringers, girders, deck, hull, and so on.
THICKNESS
Entities
string
assems
The value of the Thickness attribute for a plane flange group.
VERSION
Entities
string
assems
The value of the Version attribute for a ship.
WEIGHT_UNITS
Entities
string
assems
The value of the WeightUnits attribute for a ship units object.
See Also:
Tribon Import Options
Tribon Reader Support
CAD Import Options
