Engineering Solutions
UG Import Options- Native Reader
The UG native reader uses the ug_reader.ini file.  The UG reader also includes a browser to control the import of assemblies, the sorting of entities by component, and various other import details.  For more information, refer to the UG Part browser section.
The UG reader and part browser have the following available options:
@AssignThicknessToSolids
Value
on
Assign thickness to a solid if the owning part has an attribute with the name THICKNESS. The thickness value is the value of this attribute.
off
Do not assign thickness to solids (default).
@AttributesAsMetadata
Value
on
Import all generic attributes (global and related to single entities) as metadata.
<name>
off
Do not import generic attributes.
part
Import just the global attributes (the attributes related to the part as a whole) as metadata.
<name>
entity
Import just the entity attributes (the attributes related to single entities) as metadata.
<name>
%attribute1%attribute2%attribute3
Import specified generic attributes as metadata.
The attribute names are listed, separated by a character that you choose, and inserted as the first element of the string. The example uses '%' as a separator. You can choose another character as a separator, in case one of the listed attribute names contains '%'. HyperMesh will recognize it as it is the first character of the string.
<name>
@CleanupTol
Value
double
A negative value (default) means to use the auto cleanup tolerance.  A value greater than the calculated auto cleanup tolerance means to use that specific tolerance.
Refer to the CAD Cleanup Tolerance section.
@ColorsAsMetadata
Value
on
Read color attributes of geometric entities as metadata.
COLOR_RGB
off
Do not read color attributes (default).
@ComponentAttributes
Value
string
In batch mode, or if @Interactive = off, this corresponds to the UG Part Browser Component attributes option.
If @Interactive = on, this initializes the corresponding option in the UG Part browser.
@ComponentNameFormat
Value
string
In batch mode, or if @Interactive = off, this corresponds to the UG Part Browser Assign components by name option; the default value is "default", that is the standard component naming; to have custom component name one should set:
@ComponentNameFormat = "custom <custom1><custom2>...<customnn>"
where <customi> could be one of the following:
<Part Name>, <Part Number>, <RID-PDI>, <Layer>, <Category>, <Instance Name>, <Material Name>, <Thickness>, <UG Body ID>, <UG Tag>, <Solid Name>.
If @Interactive = on , this initializes the corresponding option in the UG Part browser.
@CoordinateSystem
Value
global
In batch mode, or if @Interactive = off, individual parts in an assembly are imported into the global coordinate system (default).
local
In batch mode, or if @Interactive = off, individual parts in an assembly are imported into their local coordinate system.
@CreateMatsAndProps
Value
on
Create materials and properties in HyperMesh if material and thickness data are found in the model (default).
off
Do not create materials and properties in HyperMesh.
@CreateWeldsInHypermesh
Value
on
In batch mode, or if @Interactive = off, welds are created in HyperMesh.
off
In batch mode, or if @Interactive = off, welds are not created in HyperMesh (default).
@DensityAsMetadata
Value
on
Read density value as metadata (default).
DENSITY
TRANSFORMATION_MATRIX
off
Do not read density value.
@DisabledLayers
Value
string
This corresponds to the UG Part Browser Disable option in Layer filtering mode: the layers to disable in the import should be listed with the same rules as for the UG Part browser entry.
@Display
Value
categories
In batch mode, or if @Interactive = off, this corresponds to the UG Part Browser Categories selection.
layerfiltering
In batch mode, or if @Interactive = off, this corresponds to the UG Part Browser Layer filtering selection (default).
@DoNotMergeEdges
Value
on
Preserve the original geometry edges, instead of merging them together during the import cleanup phase.
off
Merge edges together during the import cleanup phase (default).
@EnabledLayers
Value
string
This corresponds to the UG Part Browser Enable option in Layer filtering mode: the layers to enable in the import should be listed with the same rules as for the UG Part browser entry.
@ExportToMasterWeldFile
Value
on
In batch mode, or if @Interactive = off, a master weld file is created.
off
In batch mode, or if @Interactive = off, no master weld file is created (default).
@ImportBlanked
Value
on
In batch mode, or if @Interactive = off, imports entities that are hidden, blanked, or no show.
off
In batch mode, or if @Interactive = off, do not import entities that are hidden, blanked, or no show (default).
@ImportForVisualizationOnly
Value
on
Import the model for visualization purposes only.
This skips many of the import steps (cleanup, stitching, solid creation, and so on) to provide a faster import. The resulting model may not be suitable for other uses.
off
Import the model in the normal fashion (default).
@ImportParameters
Value
on
Import parameters.  Parameters are imported even if they are not associated to any geometry.  See also @ParametersPrefix.
For parameters that have relationships to other parameters, parameter expressions are created.
In addition, @DoNotMergeEdges is automatically set "on" when using this option, to give the best results for edge parameter association.
CADIO_FEAT_PARAM_IDS
FULL_NAME
off
Do not import parameters (default).
@ImportWaveLinkedGeometry
Value
on
Import geometry created by the WAVE Geometry Linker.
off
Do not import geometry created by the WAVE Geometry Linker (default).
@IncludeWireFrame
Value
on
In batch mode, or if @Interactive = off, import free curves and points (default).
off
In batch mode, or if @Interactive = off, do not import free curves and points
@Interactive
Value
on
The UG Part browser comes up. This is the default in GUI mode, and is ignored in batch mode.
off
The UG Part browser does not come up. This is the default in batch mode.
@MatchUGAssemblyHierarchy
Value
on
The assembly hierarchy created in HyperMesh is the same as seen in NX.
off
An assembly level is created in HyperMesh for parts contained in an assembly (default).
@MaterialName
Value
string
Name of the CAD attribute containing the material name data of the current part.
Default is "Material"; meaningful only if @AttributesAsMetadata = "part". It only generates temporary data used by the ExtAPI cadassm tool.
@Merge
Value
on
In batch mode, or if @Interactive = off, the MERGE metadata is generated.
off
In batch mode, or if @Interactive = off, the MERGE metadata is not generated.
@MetadataPrefix
Value
string
The string is prefixed to all metadata names. No prefix is used by default.
See CAD Metadata Naming for more details.
@Midsurface
Value
on
In batch mode, or if @Interactive = off, and when @Display= layerfiltering, midsurfaces are imported.
off
In batch mode, or if @Interactive = off, and when @Display= layerfiltering, midsurfaces are not imported (default).
@ModelAttributes
Value
string
In batch mode, or if @Interactive = off, this corresponds to the UG Part Browser Model attributes option.
@OriginalIdAsMetadata
Value
on
Import original CAD entity IDs as metadata.
ORIGINAL_ID
off
Do not import original CAD entity IDs as metadata (default).
@ParametersPrefix
Value
string
Only parameters with this prefix will be imported.  All others will not be imported.
Default is "HW_"; meaningful only if @ImportParameters = "on".
@PartNumber
Value
string
Name of the CAD attribute containing the part number info of the current part.
Default is "PartNumber"; meaningful only if @AttributesAsMetadata = "part". It only generates temporary data used by the ExtAPI cadassm tool.
@PropertyName
Value
string
Name of the properties created in HyperMesh. It can contain “special” strings that will be replaced with their meaning: <COMPONENT_NAME> is the name of the component to which the property is associated, <PROPERTY_CARD_NAME> is the name of the property card.
@SaveSettingsAsDefault
Value
on
In batch mode, or if @Interactive = off, the ug_reader.ini file is saved with the current settings.
off
In batch mode, or if @Interactive = off, the ug_reader.ini file is not saved (default).
@ScaleFactor
Value
double
Defines the model scaling factor during import.
Default is 1.0.
@SelectedCategories
Value
string
This corresponds to the UG Part browser option Categories; they should be listed as they are written in the command file string: “<name1_length> <name1> <name2_length> <name2>…”, where <name<i>_length> is a number representing the string length of the ith category name.
@SelectedParts
Value
string
This corresponds to the UG Part Browser Parts selection; they should be listed as they are written in the command file string: “<handle1_length> <handle1> <handle2_length> <handle2>…”, where <handle<i>> is a string representing the handle of the part as retrieved by UGOpen libraries and <handle<i>_length> is the string length.
@ShowAllCategories
Value
on
In batch mode, or if @Interactive = off, and @Display = categories, all categories will be retrieved and displayed.
off
In batch mode, or if @Interactive = off, and @Display = categories, only categories in the top assembly will be retrieved and displayed (default).
@SkipCreationOfSolid
Value
on
Read surfaces, but do not create solid entities.
off
Create solid entities (default).
@Solid
Value
on
In batch mode, or if @Interactive = off, and when @Display= layerfiltering, solids are imported (default).
off
In batch mode, or if @Interactive = off, and when @Display= layerfiltering, solids are not imported.
@SplitPeriodicFaces
Value
on
Split periodic surfaces to improve the quality and robustness of the import (default).
off
Import periodic surfaces as a single surface with a seam edge.
@StitchDifferentSheets
Value
on
Stitching across different sheet bodies belonging to the same UG part/instance is enabled (default).
off
Stitching across different UG sheet bodies is disabled.
@TagsAsMetadata
Value
on
Create entity name as metadata (default).
TAG
FromBody
Take entity from its parent body and create as metadata.
TAG
off
Do not read tags.
@ThicknessName
Value
string
Name of the CAD attribute containing the thickness data of the current part.
Default is "Thickness"; meaningful only if @AttributesAsMetadata = "part". It only generates temporary data used by the ExtAPI cadassm tool.
@UID
Value
string
Name of the CAD attribute containing the UID info of the current part.
Default is "UID"; meaningful only if @AttributesAsMetadata = "part". It only generates temporary data used by the ExtAPI cadassm tool.
@UniqueIdAsMetadata
Value
on
Create metadata to track the unique CAD ID (default).
For parts and assemblies the value is the name.
For geometrical entities for each assembly level, the assembly instance tag is appended to the ORIGINAL_ID using "-".
For example:
No body entities present in the assembly: 20
Body entities present in a single level assembly: 1-20
Body entities present in a multiple level assembly: 1-4-2-20
The same identifier can be obtained for two entities when a single entity is split during import.
UNIQUE_ID
off
Do not create metadata to track the unique CAD ID.
See Also:
UG Metadata Support
UG Part Browser
UG Reader Support
CAD Import Options
