Engineering Solutions
UG Metadata Support- Native Reader
The UG reader generates the following metadata:
CADIO_FEAT_PARAM_IDS
Entities
entity
array
points
lines
surfs
solids
This metadata is assigned to the geometric objects for which the imported parameters apply.  One or more parameters may control a particular object.
This association is only for parameters that are directly assigned to the object in NX.  The association is not done for any parameters that may be part of an expression, since that relationship can be determined from the parameter expression itself.
Generated when @ImportParameters = on
COLOR_RGB
Entities
string
points
lines
surfs
solids
Three RGB values, ranging from 0 to 255, indicating the color of the entity in the CAD model.
Generated when @ColorAsMetadata = on
DENSITY
Entities
double
solids
The density value, as specified in the CAD model, if one exists.
Generated when @DensityAsMetadata = on
FULL_NAME
Entities
string
params
Parameters are named with the NX default name.
This contains the full name of the parameter, as defined in NX.
MERGE
Entities
integer
comps
Set to 1 if the Merge assemblies option is chosen in the Part browser.
Generated when @Merge = on
MODELUNIT
Entities
integer
comps
The model units specified in the CAD file.  Values include:
1 = inches
2 = millimeters
4 = feet
5 = miles
6 = meters
7 = kilometers
8 = mils
9 = microns
10 = centimeters
11 = microinches
12 = decimeters
13 = yards
This is always generated.
NX_MIDSURFACE
Entities
integer
comps
Generated and set to 1 if the component was created during import to contain midsurface geometry.
ORIGINAL_ID
Entities
string
points
lines
surfs
solids
The original CAD entity ID.
Generated when @OriginalIdAsMetadata = on
TAG
Entities
string
points
lines
edges
surfs
solids
The tag (name) of the entity as read from the CAD model, if one exists.
Generated when @TagsAsMetadata = on
TRANSFORMATION_MATRIX
Entities
string
solids
A 4x4 transformation matrix from the global reference system to the part reference system.
UG_DESCRIPTIVE_PARTNAME
Entities
string
assems
comps
The UGNX descriptive part name of the assembly/comp. For example, its attribute DB_PART_DESC. This is always generated, if present.
UG_PARTNAME
Entities
string
assems
comps
The UGNX part name of the assembly/comp. This is always generated.
UNIQUE_ID
Entities
string
assems
points
lines
surfs
solids
For assemblies the name of the UG assembly.
For geometrical entities a combination of the body identifiers and the entity ID.
Generated when @UniqueIdAsMetadata = on
<name>
Entities
integer
double
string
points
lines
surfs
solids
comps
assems
The <name> field is the UG attribute name and the integer/double/string is the value of the UG attribute.
Generated when @AttributesAsMetadata = on
See Also:
UG Import Options
UG Reader Support
CAD Import Options
