Engineering Solutions uses the proprietary (.hm) format for database files which include geometry, meshing, connectors, loads and forces, materials, and everything else that is necessary to pre-process a model prior to sending it to a solver.
In addition, Engineering Solutions can import and export Connectors, Finite Element models, Geometry and multiple Engineering Solutions models, and can also export HyperView 3d (h3d) files.
For more detail, see Types of Interfacing in Engineering Solutions and Currently Supported Versions of third-party applications such as CAD packages or solvers.
