Engineering Solutions
Update Model
Update Model
Update Model
Materials and Properties
The Materials and Properties panel allows you to quickly create or edit a material or a property and assign it accordingly. Alternatively, you can visualize and select a material from the database, or customize and add materials into the database.
mat_and_prop_task
Contacts
Default contacts that are required for the drop test are automatically created by the Drop Test Manager. Default contacts created by the utility cannot be modified.
contacts_task
See Also:
Drop Test Manager
