Engineering Solutions
Save and Review Results
Solve, Post-Process and Reports
The Solve panel allows you to save the input setup file to a user defined location and launch the analysis from within the panel. Also, the termination times and the animation output frequencies can be controlled before saving the input files. The View Results button launches HyperView. The Export button allows you to simply export the deck without submitting the job.
drop_test_04
See Also:
Drop Test Manager
