In order to install/invoke on a PC, follow the below procedure:
2. | Create a folder on any local drive. This will be the template working directory. |
3. | Unzip the file using any of the zip utilities available. |
4. | Select an option where you see the following items under the main folder under the template working directory: |
• | A folder called tclincludes |
• | A file named drop_test.pmd |
• | A file named drop_test.pmt |
5. | Start a new HyperMesh session with the RADIOSS user profile. |
6. | Click Applications > Process Manager. |
7. | Under the Process Manager utility, click browse and select the file drop_test.pmt to invoke the drop test process template. |
