User Profiles: |
Incremental_RADIOSS Incremental_LS-DYNA RADIOSS One Step Die Module  |
Use the Renumber panel to renumber entities. You may also enter a value by which to offset the IDs of entities.
When the ID to be assigned to an entity is already assigned to another entity, HyperMesh adds the increment to the ID until a unique ID is found. Because of this, it may be necessary to move the entities out of the way by initially renumbering all of the entities starting with a large ID, and then renumber again with the desired IDs.
The Renumber panel contains the following subpanels and command buttons:
Use the Single subpanel to renumber individual entities or specific, custom-picked groups of entities.
 Panel Inputs
Use the All subpanel to renumber all entities in the model, regardless of type.
 Panel Inputs
The following action buttons appear throughout the subpanels:
 CommentsWhen the ID to be assigned to an entity is already assigned to another entity, HyperMesh adds the increment to the ID until a unique ID is found. Because of this, it may be necessary to move the entities out of the way by initially renumbering all of the entities starting with a large ID, and then renumber again with the desired IDs.  |
 Each time you click offset, the numbers are offset by the value specified after offset =.
 UndoUse offset again, with the menu item offset = set to the negative value of the original offset value.
 CommentsIt is possible to offset by both positive and negative values, provided that the offset IDs of all selected entities are greater than zero.  |
 The total number and the range of numbers of the selected entity type are displayed as a message in the status bar.
 CommentsIf entities are selected, the total number and range of numbers includes only the selected entities.  |
An Alphabetical List of Panels
