Manufacturing Solutions
Ruled Panel
Ruled Panel
Ruled Panel
User Profiles:
Incremental_LS-DYNA
Die Module
Use the Ruled panel to create surfaces and/or meshes of plate elements from nodes, lines, and/or line segments, in any combination. Nodes in the mesh being created are placed on a surface created on a linear basis between the two sets of selected entities.
Subpanels and Inputs
There are no subpanels on the Ruled panel. All inputs and command buttons are located on the main panel.
Panel Inputs
Input
Action
node list / line list
There are two identical switches which allow you to pick a node list or a line list.  The surfaces or meshes will be generated in the intervening space between the selected nodes and/or lines.
meshing options
mesh, keep surf: creates a surface from the selected entities and then generates a mesh on the created surface.  The created surface is retained along with the mesh.
mesh, dele surf: creates a surface from the selected entities and then generates a mesh on the created surface.  The created surface is then deleted and only the corresponding mesh is retained.
mesh w/o surf: This option creates a mesh between the selected entities using linear interpolation without creating a surface.
surface only: creates a surface from selected entities, but does not create a mesh.  You can use the resulting surface to perform any desired geometry cleanup functions or automeshing.
auto reverse
When elements are generated, the edges used to create this mesh can be ordered in different directions.  This causes HyperMesh to create a mesh that crosses itself, resembling a bow tie.  The order of the edges is determined by the order in which the nodes were selected or the direction of the selected line(s).  To prevent "bow ties" from occurring, the default auto reverse parameter is provided to insure that elements are generated with a similar order on each side of the mesh.  Toggle auto reverse to no reverse to disable this feature.
Command Buttons
The following action buttons appear:
Button
Action
create
Creates the ruled surface and/or mesh.
reject
Undoes the most recent ruled creation.
return
Exits the panel.
How do I...
Build a surface between two rows of nodes
Build a surface between a row of nodes and a line
Build a surface between lines or between line segments
See also
An Alphabetical List of Panels
HM-3110: Mesh without Surfaces
