Engineering Solutions
Abaqus Connector Types
Previous topic Next topic Expand/collapse all hidden text
Abaqus fastener
CFG abaqus 3 fastener
*filter spot
*head
*body 0
rod 13 3
*post prop_fastener.tcl
cfg_abaqus_3_fastener
Description: Creates a CONN3D2 element.
This realization uses the prop_fastener.tcl property script.
This script is used while creating Abaqus Fasteners in the Spot panel. It does the following tasks.
Organizes the realized weld elements into their respective components, based upon the link they are connected to. Thus, if a weld is created between comp_1(1) and comp_2(2), the script creates a component collector with the name HM_CONN3D2<id> and organizes all the welds created as links between these two components into this collector. This collector is later referenced as the element set while creating the Groups (Interfaces).
Creates the following properties/materials collectors:
-HM_ConnectorBehavior<id>: This material collector is created with the *CONNECTOR BEHAVIOR card associated with it.
-HM_ConnectionSection_<id>: This property collector is created once per model (card image CONNECTOR SECTION). The property is assigned to each HM_CONN3D2 component collector and carries the material HM_ConnectorBehavior.
-HM_FastenerProperty_r_<radius in property>: This property collector is created with the *FASTENER PROPERTY card associated with it. It defines the RADIUS and the degree of freedom definition of the fastener.
Creates Groups (HM Interfaces) with the name HM_FastenerInteraction<id> and with the *FASTENER card associated with it. The fastener connects two component collectors and refers to the fastener property card mentioned above. It can also show the link elements to which the weld elements are linked via the Automatic_Surface_from_components option.
-If any system option (Single System ,1- System per layer or 2- Systems per layer) is used in the Spot panel during realization, this script creates ORIENTATION systems in the current collector with the name HM_ORI<weld_id>_n<node_id>. A property HM_ConnectorSection_<CONN3D2 element id> is created and assigned per element. Depending on whether one or two systems per layer are created the property points to one or both systems.
Abaqus acm (equivalenced-(T1+T2)/2)
CFG abaqus 4 acm (equivalenced-(T1+T2)/2)
*filter spot
*style acm 1
*head
rbe3 1 0
*body 0
hex8 1 1
*post prop_abaqus_acm.tcl
cfg_abaqus_4_acm
Description: Creates hexa element with DCOUP3D elements projecting and connecting to the surrounding shell elements. This realization uses the shell thickness to calculate the hexa offset from the shell elements. In the case where the model is a 3T connection, the acm (equivalenced-(T1+T2)/2) realization will join the hexa elements.
This realization uses the prop_abaqus_acm.tcl property script.
This script is used while creating acm (equivalenced-(T1+T2)/2) / (detached-(T1+T2)/2) /shell gap in the Spot panel and adhesives in the Area panel. It does the following tasks.
Organizes the realized weld elements [acm Equivalence-(T1+T2/2)] into the respective components based upon the *HEAD and the *BODY information of the weld. During realization of this configuration type a solid hexa element [C3D8] is connected to the shell elements by the rbe3 elements [DCOUP3D].
-A collector with the name C3D8_comp_<id> is created with the SOLIDSECTION card image associated with it. This component contains all of the solid C3D8 elements which are created during realization.
-A collector with the name DCOUP3D_comp_<id> is created, containing all of the DCOUP3D elements created as the heads to the weld element.
If this script is called during the realization of adhesives in the Area panel, this script creates the above two components by different names:
hexa_comp_<id> for the Hexa elements
rbe2_comp_<id> for the rbe elements
The script also creates a property collector named prop_<id>, with the SOLIDSECTION card image associated to it. This property collector is referenced to the component containing the Hexa elements created during realization process (i.e. C3D8_comp_<id> in the case of spots, or hexa_comp_<id> in the case of adhesives).
Abaqus sealing
CFG abaqus 5 sealing
*filter spot
*head
rbe3 1 0
*body 0
rod 13 1
cfg_abaqus_5_sealing
Description: Creates DCOUP3D elements for the head and element for the body. The head elements project and connect to the nodes of the adjoining shell elements.
Abaqus bush
CFG abaqus 6 bush
*filter spot
*head
rigidlink 1 1
*body 0
rod 13 1
cfg_abaqus_6_bush
Description: Creates KINCOUP elements for the head and element for the body. The head elements project and connect to the nodes of the adjoining shell elements.
Abaqus bolt (b31)
CFG abaqus 7 bolt (b31)
*filter bolt
*style bolt 0
*head
rigidlink 1 12
*body 0
bar2 9 1
*post prop_abaqus_b31.tcl
cfg_abaqus_7_bolt
Description: Creates KINCOUP elements for the head and B31 element for the body. The head elements project and connect to the nodes of the adjoining shell elements that form the hole, and also to the second row of nodes to form the washer layer. The connector location can be on the edge of the hole, center of the hole, midpoint in between the two, holes or on the second row of nodes which form the washer layer.
This connector also uses the script prop_abaqus_b31.tcl.
This script updates the direction nodes of a group of bar elements created during realization to use the y axis.  The *bardirectionupdate command is called to update the orientation node of bar element along Y-axis.
Abaqus hinge (b31)
CFG abaqus 8 hinge (b31)
*filter bolt
*style bolt 0
*head
rigidlink 1 12
*body 0
bar2 9 1 dofs=4
cfg_abaqus_8_hinge
Description: Creates KINCOUP elements for the head and B31 element for the body. The rot x degree of freedom is constrained. The head elements project and connect to the nodes of the adjoining shell elements that form the hole, and also to the second row of nodes to form the washer layer. The connector location can be on the edge of the hole, center of the hole, midpoint in between the two holes, or on the second row of nodes which form the washer layer.
Abaqus adhesives
CFG abaqus 9 adhesives
*filter area
*style adhesive 1
*head
rbe3 1 0
rigid 1 0
*body 1
hex8 1 1
penta6 1 1
cfg_abaqus_9_adhesive
Description: Creates a row of hexa/penta elements for the body and numerous DCOUP3D/KINCOUP elements for the head. The head elements project and connect to the nodes of the adjoining shell elements. If there is a direct normal projection then a KINCOUP element will be used, if there are only non-normal projections then DCOUP3D elements will be created. The size (thickness) for the hexa and/or penta elements depends on the chosen option: shell gap, (T1+T2)/2, mid thickness, const. thickness, maintain gap.
Note:The exact hexa position is also influenced by the option consider shell thickness and offset for hexa positioning. See hexa positioning for hexa adhesives and ACMs for details.
The script also creates a property collector named prop_<id>, with the SOLIDSECTION card image associated to it. This property collector is referenced to the component containing the Hexa elements created during realization process (ie C3D8_comp_<id> in the case of spots, or hexa_comp_<id> in the case of adhesives).
Abaqus rbe3 (load transfer)
CFG abaqus 31 rbe3 (load transfer)
*filter spot
*style mpc 1
*head
*body 0
rbe3 1 1 dofs=123
cfg_abaqus_31_rbe3
Description: Creates DCOUP3D elements for the body. The degrees of freedom are constrained in the x, y, and z axes for the dependant nodes.
Abaqus clip
CFG abaqus 50 clip
*filter bolt
*style bolt 1
*head
*body 0
rigidlink 1 2
cfg_abaqus_50_clip
Description: Creates a KINCOUP element. The element projects and connects to the nodes of the adjoining shell elements that form the hole, and also the nodes that form the washer layer. The connector location can either be on the edge of the hole, center of the hole, midpoint in between the two holes, or on the second row of nodes which form the washer layer.
Abaqus bolt (washer 1) cbar
CFG abaqus 51 bolt (washer 1) cbar
*filter bolt
*style bolt 0
*head
rigidlink 1 12
*body 0
bar2 9 1
cfg_abaqus_bolt_washer_1_cbar
Description: Creates KINCOUP elements for the head and B31 element for the body. The head elements project and connect to the nodes of the adjoining elements, forming the hole and also the second row of nodes which form the washer layer. The connector location can either be on the edge of the hole, center of the hole, midpoint in between the two holes, or on the second row of nodes which form the washer layer.
Abaqus bolt (spider)
CFG abaqus 54 bolt (spider)
*filter bolt
*style bolt 1
*head
*body 0
rigidlink 1 1
cfg_abaqus_54_bolt_spider
Description: Creates a KINCOUP element, which projects and connect to the nodes of the adjoining elements which form the hole. The connector location can either be on the edge of the hole, center of the hole, midpoint in between the two holes, or on the second row of nodes which form the washer layer.
Abaqus bolt (washer 2)
CFG abaqus 55 bolt (washer 2)
*filter bolt
*style bolt 0
*head
rigidlink 1 1
rigidlink 1 2
*body 0
rigid 1 1
cfg_abaqus_55_bolt_washer2
Description: Creates KINCOUP elements for the head and the body. There are two individual KINCOUP elements at the head of the connection, one to connect to the inner row of nodes, and a second to connect to the washer layer nodes. The connector location can either be on the edge of the hole, center of the hole, midpoint in between the two holes, or on the second row of nodes which form the washer layer.
Abaqus bolt (washer 2 alt)
CFG abaqus 56 bolt (washer 2 alt)
*filter bolt
*style bolt 0
*head
rigidlink 1 1
rigidlink 1 3
*body 0
rigid 1 1
cfg_abaqus_56_bolt_washer2_alt
Description: Creates KINCOUP elements for the head and the body. There are two individual KINCOUP elements at the head of the connection, one to connect to the inner row of nodes, and a second to connect to the washer layer nodes. The KINCOUP head element that connects to the washer layer nodes only connects to every other node on the washer layer. The connector location can either be on the edge of the hole, center of the hole, midpoint in between the two holes, or on the second row of nodes which form the washer layer.
CFG abaqus 57 bolt (washer 1)
*filter bolt
*style bolt 0
*head
rigidlink 1 12
*body 0
rigid 1 1
cfg_abaqus_57_bolt_washer1
Description: Creates KINCOUP elements for the head and body. The head elements project and connect to the nodes of the adjoining elements, forming the hole and also the second row of nodes which form the washer layer. The connector location can either be on the edge of the hole, center of the hole, midpoint in between the two holes, or on the second row of nodes which form the washer layer.
Abaqus bolt (washer 1 alt)
CFG abaqus 58 bolt (washer 1 alt)
*filter bolt
*style bolt 0
*head
rigidlink 1 13
*body 0
rigid 1 1
cfg_abaqus_58_bolt_washer_1_alt
Description: Creates KINCOUP elements for the head and body. The head elements project and connect to the nodes of the adjoining elements, forming the hole and also the second row of nodes which form the washer layer. The head only connects to every other node on the washer layer. The connector location can either be on the edge of the hole, center of the hole, midpoint in between the two holes, or on the second row of nodes which form the washer layer.
Abaqus bolt (cylinder bolt)
CFG abaqus 60 bolt (cylinder rigid)
*filter bolt
*style bolt 4
*head
rigidlink 1 1
*body 0
rigid 1 1
*post prop_cylinder.tcl
cfg_abaqus_60_cylinderbolt
Description: Creates a KINCOUP element for the body as well as for the head elements.
Read mesh independent Realization methods in the Bolt panel for further information to cylinder type bolts.
This realization uses the prop_cylinder.tcl property script.
This script is used while creating bolt (cylinder rigid) and bolt (cylinder bar) in the Bolt panel (Abaqus, Nastran, OptiStuct). It organizes the realized bolt elements into the respective components based upon the *HEAD and the *BODY information of the bolt:
A collector with the name Rigid_M<diameter> is created. This component contains all of the rigid head elements and the rigid body elements, if available.
A collector with the name Beam_M<diameter> is created. This component contains all of the bar2 head elements, if available. This component then gets a property Beam_M assigned (*BEAMSECTION or PBEAM).
Abaqus bolt (cylinder bar)
CFG abaqus 61 bolt (cylinder bar)
*filter bolt
*style bolt 4
*head
rigidlink 1 1
*body 0
bar2 9 1
cfg_abaqus_61_bolt_clinderbar
Description: Creates a B31 element for the body and KINCOUP elements for the head elements.
Abaqus acm (detached-(T1+T2)/2)
CFG abaqus 70 acm (detached-(T1+T2)/2)
*filter spot
*style acm 2
*head
rbe3 1 0
*body 1
hex8 1 1
cfg_abaqus_70_acm
Description: Creates a hexa element with DCOUP3D elements projecting and connecting to the surrounding shell elements. This realization uses the shell thickness to calculate the hexa offset from the shell elements. In the case where the model is a 3T connection, the acm (detached-(T1+T2)/2) realization will not join the hexa elements.
Abaqus acm (shell gap)
CFG abaqus 71 acm (shell gap)
*filter spot
*style acm 3
*head
rbe3 1 0
*body 0
hex8 1 1
cfg_abaqus_71_acm
Description: Creates a hexa element with DCOUP3D elements projecting and connecting to the surrounding shell elements. This realization does not use the shell thickness to calculate the hexa offset, therefore the hexa will project and be touching the shell elements.
Abaqus acm (shell gap + coating)
CFG abaqus 72 acm (shell gap + coating)
*filter spot
*style acm 4
*body 0
hex8 1 1
acm_shellgap_coating_2
Description: Creates one hexa cluster per connector and realizes a node to node connection to the linked shell meshes by adjusting it (shell coating). Different patterns are available. This is driven by the number of hexas. The appearance can be influenced via the diameter and the washer layer activation.
Abaqus acm (general)
CFG abaqus 73 acm (general
*filter spot
*style acm 3
*head
rbe3 1 0 dofs=123
*body 0
hex8 1 1
cfg_abaqus_73_acm_general
Description: Consolidates several ACM definitions into one general, flexible ACM definition. Besides mid thickness, constant thickness, and maintain gaps, the definition of several coats with different hexa patterns is available.
The script performs the following tasks:
1.Organizes the DCOUP3D elements into a component with the name DCOUP_3D_# (# starts with 1 and increments as 1, 2, 3, and so on, with every new component).
2.Organizes the HEXA elements into a component with the name C3D8_comp_# (# starts with 1 and increments as 1, 2, 3, and so on, with every new component).
3.Creates properties with the SOLIDSECTION card image with the name prop_# (# starts with 1 and increments as 1, 2, 3, and so on, with every new connector) which is referenced by the above HEXA component.
4.Creates materials with the name prop_#, which is referenced by the above properties.
Abaqus seam-quad (angled+capped+L)
CFG abaqus 101 seam-quad (angled+capped+L)
*filter seam
*style quad 4
*head
*body 0
quad4 1 1
cfg_abaqus_101_seamquad_anglecapped
Description: Creates a quad row with tria caps at the seam ends. In addition, a certain pure quad element pattern is created around the seam elements (shown here in red). These elements normally get imprinted into the shell links. The exact geometry of the seam can be influenced by certain attributes in the Seam panel.
This realization is mainly intended to be used for lap welds.
Note:You can revert the direction of quad seam connectors during the next realization by activating the reverse direction check box in the Seam panel.
Abaqus seam-quad (angled+capped+T)
CFG abaqus 102 seam-quad (angled+capped+T)
*filter seam
*style quad 5
*head
*body 0
quad4 1 1
cfg_nastran_102_seam_quad_angled_capped_t
Abaqus seam-quad (vertical+angled)
CFG abaqus 103 seam-quad (vertical+angled)
*filter seam
*style quad 1
*head
*body 0
quad4 1 1
cfg_abaqus_103_seamquad_verticalangled
Description: Creates two quad rows--the first one perpendicular to the opposite shell link, and the second one with a certain angle to the first one. In addition, a certain pure quad element pattern is created around the seam elements (shown here in red). These elements normally get imprinted into the shell links. The exact geometry of the seam can be influenced by the angle value.
This realization is can be used for both lap- and T-welds.
Abaqus seam-quad (angled)
CFG abaqus 104 seam-quad (angled)
*filter seam
*style quad 2
*head
*body 0
quad4 1 1
cfg_abaqus_104_seamquad_angled
Description: Creates one quad row under a certain angle. The angle is measured between the quad row and the perpendicular projection from the free edge to the opposite shell link. In addition, a certain pure quad element pattern is created around the seam elements (shown here in red). These elements normally get imprinted into the shell links. The exact geometry of the seam can be influenced by the angle value.
This realization is can be used for both, lap- and T-welds.
Abaqus Mastic
CFG abaqus 105 Mastic
*filter spot
*head
rbe3 1 0
*body 0
spring 1 1
spring 1 1
spring 1 1
*post prop_mastic.tcl
cfg_abaqus_105_mastic
Description: Creates SPRING elements for the body, and projects and connects to the adjoining shell/solid elements with DCOUP3D elements.
The realization uses the prop_mastic.tcl property script.
1.Organizes the SPRING elements into components with the names SPRING_X, SPRING_Y and SPRING_Z.
2.Organizes the DCOUP3D elements into the component DCOUP_3D_no_prop.
3.Creates properties with the SPRING card image, and names the properties spring_prop_K1_ElemId-##, spring_prop_K2_ElemId-##, and spring_prop_K3_ElemId-## (where ## is the element ID of the SPRING element).
Note:New components will only be created if their are not any components with the same names that already exist; otherwise the existing components are used.
Abaqus hexa (adhesive)
CFG abaqus 106 hexa (adhesive)
*filter seam
*style continuous 3
*head
rbe3 1 0
rigid 1 0
*body 0
hex8 1 1
cfg_abaqus_106_hexa_adhesive
Description: Creates a row of hexa elements for the body, and numerous DCOUP3D elements for the head. The head elements project and connect to the nodes of the adjoining shell/solid elements. The hexa elements are projected so that they touch the shell/solid elements of the connecting components.
This realization also uses the prop_abaqus_acm.tcl property script.
1.Organizes the COUP3D elements into a component with the name DCOUP_3D_# (# starts with 1 and increments as 1, 2, 3, and so on with every new component).
2.Organizes the HEXA elements into a component with the name C3D8_comp_# (# starts with 1 and increments as 1, 2, 3, and so on with every new component).
3.Creates properties with the SOLIDSECTION card image and assign them the name prop_# (# starts with 1 and increments as 1, 2, 3, and so on with every new component) which is referenced by the above HEXA component.
Abaqus seam (vectors)
CFG abaqus 107 seam (vectors)
*filter seam
*style continuous_vec 1
*head
*body 0
quad4 1 1
cfg_abaqus_107_seam_vectors
Description: Creates perpendicular and parallel vectors to the surface along a line/nodelist. On exporting the connector file, a vector file (.asc format) containing the vector information is also exported for this realization.
Abaqus hexa (tapered T)
CFG abaqus 108 hexa (tapered T)
*filter seam
*style continuous 6
*head
rbe3 1 0
rigid 1 0
*body 0
hex8 1 1
hexa_tapered_t
Description: Intended to be used for t-cases. The size and exact position can be defined thickness dependent, or the exact dimension and position parameters can be given.
Abaqus fastener-nodes
CFG abaqus 110 fastener-nodes
*filter spot
*head
*body 0
mass 99 2
*post prop_fastener_nodes.tcl
cfg_abaqus_110_fastener_nodes
Description: Creates a Node Set that contains the nodes that are selected to create the connector element, and creates an empty Element Set. Connector elements are not created for this realization type. Abaqus creates the required connector elements on its own.
This realization uses the prop_fastener_nodes.tcl property script.
This script is used while creating Abaqus Fasteners-Nodes in the Spot panel. It does the following tasks.
Organizes the realized weld elements into their respective components, based upon the link they are connected to. Thus, if a weld is created between comp_1(1) and comp_2(2), the script creates a component collector with the name HM_HMCONN_<id> and organizes all the welds (Dummy element) created as links between these two components into this collector. This collector is later referenced as the element set while creating Groups (Interfaces).
Creates groups with the card image *FASTENER, and assigns them the name HM_FastenerInteraction_<id>. The fastener connects two component collectors and refers to the fastener property card. The Automatic_Surface_from_components option is used to show the elements to which the weld elements are linked to.
Creates the following properties/material collectors:
oHM_ConnectorBehavior<id>: This material collector is created with the *CONNECTOR BEHAVIOR card assigned to it.
oHM_FastenerProperty_r_<radius in property>: This property collector is created with the *FASTENER PROPERTY card assigned to it.
oHM_ConnectionSection_<id>: This property collector is created once per model (card image *CONNECTOR SECTION). The property is assigned to each HM_CONN3D2 component collector and carries the material HM_ConnectorBehavior.
Creates the following sets:
oHM_FastenerNodes_Node_Set1: Contains the selected nodes for the Fastener.
oHM_HMCONN_<id>: This is the dummy elset. The connector element is created and collected based on the nodeset HM_FastenerNodes_Node_Set1 assigned to this elset. You can refer the elset to outputblock.
Abaqus bolt (step hole)
CFG abaqus 114 bolt (step hole)
*filter bolt
*style bolt 6
*head
rigidlink 1 1
*body 0
bar2 9 1
cfg_abaqus_114_bolt_step_hole
Description: This realization creates a B31 element for the bolt shaft and connects to the solids' nodes with numerous KINCOUP rigid elements based on the given bolt/hole parameters. It connects two solids through holes, or it connects one solid through a hole with a solid blind hole.
Abaqus bolt (threaded step hole)
CFG abaqus 115 bolt (threaded step hole)
*filter bolt
*style bolt 7
*head
rigidlink 1 1
*body 0
bar2 9 1
cfg_abaqus_115_bolt_threaded_step_hole
Description: Connects two solids through holes, or connects one solid through a hole with a solid blind hole. A thread length can be defined to define the dimensions of the rigid elements connecting the bolt shaft models as a bar.
